Re: Pressure assist for low flow toilet?
Posted by HUBE on July 15, 2003 at 15:49:16:
In response to Re: Pressure assist for low flow toilet?
: It is possible to add a modification to a regular toilet to enhance its flush efficiency? We plan to replace our old wall hung guzzler with a Crane Rexmont 1.6 gal/flush model, and worry if we have to flush 3 times we defeat the purpose. Thanks. Jenny; the Crane low flush will flush ok on a single flip of the lever. If in any case you need more "flush-ability", just hold the lever down a second or so longer.Mine operates on a 30-50 pressure range. (well system), so if your in the city it should have a higher pressure ... Hube
Replies to this post
There are none. |
