Re: Greenboard vs Drywall
Posted by C Weist on July 15, 2003 at 08:02:28:
In response to Re: Greenboard vs Drywall
: Is it recommended to use greenboard on an entire bathroom or can I just use it on the walls around the bathtub and use regular drywall on the walls around the vanity? Do not use "GREEN BOARD" at all , use a cement board like "HARDIBACKER" . I work in a Tile store and so many people come in with water problems from contractors using green board. If you only want to do you shower area once use a cement backer board. Sheet rock can be used on the remaining walls as long as they are not in an area where there is water against them. Around your vanity I would use a cement board, hope this helps you.
Replies to this post
There are none. |
