Re: no hot water in house
Posted by Deb on July 13, 2003 at 11:26:42:
In response to Re: no hot water in house
: Hi, I went to get into the shower and only got cold water. Last week the pressure valve was leaking and got replaced. I don't know if that could have any thing to do with this problem, but thought I would mention it. I checked the breaker switch and it was fine. I don't know what to look for. HELP. Thanks
You said that you checked the breaker, did you check the reset on the water heater thermostat?
A tripped thermostat is usually an indication of some other problem.
The Pipewench
Replies to this post
There are none.
