| Posted by hj on July 12, 2003 at 00:11:40: | |
| In response to Re: Cold radiator. | |
There are several things that can cause the problem, but you need to have a plumber or heating person check the circuit to that radiator to see what its problem is. : I have a hot water heating sytem with large cast iron radiators. They all get hot but one on the second floor. I've drained the system and ran a snake down the cold radiator to the basement. I've even put radiator and boiler cleaner in the sytem and neither things have worked. The system is full and all the radiators have been bled I still have that one radiator on the second floor that is cold. What can I do?
| There are none. |
