| Posted by Hube on July 10, 2003 at 18:41:39: | |
| In response to Re: no water in kitchen sink | |
: A few months ago I had a problem with the water in the kitchen sink. When I turned it on, it would flow then dribble. I had to turn it on and off several times before it would stay at a good flow. : About the same time, I had a new garbage dis., dish washer and new sink sprayer installed. : The problem was fixed somehow after that. The water was fine.BUt... I did notice when I turned the faucets on, the sprayer kind of jumped from pressure.The sprayer no longer works. : Now I have the same problem again. : I turn the water on and there are only drops, but this time, when I shut it back off...it still drips. : I can not get enough water to use from the faucet. : I am pretty sure the problem is between the sprayer and faucets but can not figure it out. : I hope the salution is easy enough that a old widow lady can fix. I hate paying plumbers! : Any ideas? Thanks for your help. It could be a plugged up "areator" at the spout end ,remove aereator and screen and run the water for a few minutes. It might help . good luck
| There are none. |
