| Posted by Larry Gerlach on July 09, 2003 at 13:37:37: | |
I have an older toilet that has lost it's suction. The water fills the bowl and swirlls but does not suck down. If I take a water can and pour water down the drain when I flush the toilet works properly. I suspect that the main water drain from the tank into the bowl is clogged with lime and calcium. Is there a way to get rid of the build up inside the toilet? I'd just repalce it, but it is a pink toilet that matches the tile and tub and would be hard to color match a new toilet. |
| There are none. |
