| Posted by Casman on July 09, 2003 at 09:51:10: | |
| In response to Re: Odd looking pipe | |
: What I mean is that the old faucet had copper pipe which ended in a female (nut) at the end, the new faucet has the copper pipe with a male end (like a bolt) so I have to replace what the new faucet goes into. : As for what the pipe coming out of the floor is like, picture a long wood match. The sulfer part of the match is this odd bulging part of the pipe at the end (or top) of the pipe. Just below that bulging part is a branching off of the turn off valve which is where the copper pipe from the new faucet will go. : Forgive me if I'm still not clear. A friend said that the bulging piece of pipe is a pressure valve of sorts that prevents knocking noises, does that make sense? : Crodley
It sounds like the odd piece is some sort of rigged gizmo to prevent water hammer, you can try to replace this stuff with ordinary copper fittings without the bulging thing, if it bangs or makes the pipes rattle without the gizmo, then you know what it was for,.,...good luck... |
| There are none. |
