Re: Toilet Tank hairline crack
Posted by Lori on July 08, 2003 at 20:00:55:
In response to Re: Toilet Tank hairline crack
What manufacturer made your toilet tank? I am curious because our toilet tank cracked and cause extensive water damage.
Please forward me any additional info.
thanks
: And plumbing being the way it is, that tank could crack 10 minutes after you leave on a two week vacation. When that happens, I have seen it or a similar situation many times, the water will run until you return home or the neighbors see the water running out from under your door.
: : : What do you have to lose? Gary Swart
: : Well..........You could loose quite a bit.
: : If the tank breaks, and nobody is home, it could be a huge insurance claim.
: : You would be amazed to see how much damage water will do to a home.
Replies to this post
There are none.
