| Posted by hj on July 07, 2003 at 19:00:35: | |
| In response to Re: Removal of W/D Water supply lines. | |
Gray should be polybutylene. How old is the house? Best would be to replace the tee with an elbow or coupling depending on which you need. : I am currently removing the rough-in of a washer and dryer that was in my kitchen. I would like to know how to permanently remove the water supply lines(Hot and Cold). I've traced the flexible grey pipe down into my basement utility room, where it connects off a tee that supplies another set of laundry units. There is a shut-off at this junction upstream of the two water supplies.
| There are none. |
