| Posted by Ragsplease! on July 07, 2003 at 13:25:36: | |
I am currently removing the rough-in of a washer and dryer that was in my kitchen. I would like to know how to permanently remove the water supply lines(Hot and Cold). I've traced the flexible grey pipe down into my basement utility room, where it connects off a tee that supplies another set of laundry units. There is a shut-off at this junction upstream of the two water supplies. How do you recommend I address this properly? Can the pipe(Pex?) be capped off or should I convert the Tee to an L to feed only the remaining water line? Thanks in advance |
