| Posted by mike on July 06, 2003 at 20:30:14: | |
| In response to Re: 1950s shower pan | |
Make sure there are no cracks anywhere on the curb, where the bottom and sides meet or in between the tiles. If there are any make sure you either use a good caulk and fill them up or else grout them closed. If there are no cracks make sure the water is not seeping under the door when it is closed, sometimes there is a rubber water diverter on the bottom of the door and it will tear. If you have none of these problems, you have big problems probalby to the tune of $600.00 Good luck! |
| There are none. |
