Re: washing machine drain
Posted by Deb on July 06, 2003 at 11:27:47:
In response to Re: washing machine drain
: I just moved into an older house that is on a sewer line. The problem is that the washing machine drains and backs up and sprays water out the drain hose. I have put a regular garden hose down the drain and it works fine. I have also made sure there was nothing clogging up the drain. The washer just seems to drain to fast for the drain? any suggestions woudld be appreciated
Many older homes have only (old partially clogged cast iron) 1-1/2" washing machine drainage lines. Washing machines now require 2" drainage lines. You either have an obstruction (if it is in the p-trap or standpipe, you cannot access that from the roof) or the washing machine is simply pumping water out too fast for the old drainage line to handle.
Deb
The Pipewench
Replies to this post
There are none.
