| Posted by hj on July 05, 2003 at 16:00:34: | |
| In response to Re: BaseBoard Heat | |
You have to drain the entire system to a point below that radiator. If it has been working properly, then just install the new piece the same way as the old one was. : We have forced hot water heat and I am getting ready to remove a 4 ft section of the baseboard that was damged and looking very bad. Looking for some advice on the best way to drain then replace the water from then pipes. Also there is no vent valve on that 4 ft section. Is this ok to replace the section as is (take out the section - put in a section) or should I look to install some type of value as well? Thanks in advance.
| There are none. |
