| Posted by hj on July 05, 2003 at 15:58:49: | |
| In response to Re: Moving Kitchen Waste line | |
It sounds like it would require four 90 degree turns to do what you plan. It would not be the best drain system, but as long as a cleanout was installed in the riser through your level it would be acceptable. : In a 3 story condo. On the 2nd floor. I want to move a kitchen wall over 3 ft. The wall appears to have a 3in kitchen drain line that is probably common to all condos. I want to move the wall perpindicular to the line. This would result in a 90deg. turn at the ceiling and a 90 deg turn at the floor back the the line. Is this possible and would it be within code? : thanks
| There are none. |
