Re: PVC/ABS pipe size
Posted by Jesse on July 05, 2003 at 08:20:40:
In response to Re: PVC/ABS pipe size
I am installing a whirlpool bath , a toilet and a sink, can I use 1 1/2" pipe on tub and sink?
and what is the best for the toilet, 3" or 4", also the vent pipe, can I use 3" for toilet and
1 1/2" for to tub and sink to connect to the 3" also I would like to end the vent in the attic as the plumber did on the previous job here.
also I am using cpvc 3/4 for water lines, I have a 30G HWH, I will tap into the cold water just after the filter as it comes from the accumilator tank just below the HW htr. The mfg says it reccomends a tempering valve( is it neccessary to use the as we are use to tempering our own water as it comes out.
I am using the tools 1/2 & 3/4 to crimp the cpvc, is this good.
This is long, I thank you for any help.
Jesse
Replies to this post
There are none.
