| Posted by hj on July 04, 2003 at 18:45:16: | |
| In response to Re: 1950s shower pan | |
The pan is a good possibility, since they used tar paper mostly at that time and it would deteriorate. But there could be other reasons so you have to check all possibilities before tearing it up. : We have a 1950s home on a slab and are having a problem with a leak from around the tile shower. The wood on the door facing next to the shower stays wet and the older tile has cracked along the floor of the door. We've been told two things - the leak must be coming from the shower fixtures inside the wall - but there is no damage on the outside fixture wall. Second, we've been told it is the older shower drain pan with holes that is leaking. There seems to be 4 or 5 inches of concrete on top of this drain pan and we'd surely like an experienced opinion before we tear up all this tile and concrete. Help! Thanks.
| There are none. |
