| Posted by Hube on July 03, 2003 at 18:26:27: | |
| In response to Re: Low Pressure cutoff valve | |
: Is there a valve that I can use to protect my house pressure? I am on a well and have limited water. : If a hose is left on too long, it will drain my well. : I am looking for some type of valve that would cut off the flow to the hose if the water dropped below a set point ( say 30 lbs). : Any ideas? : Thanks Alan; i can't think of any Flow balancing valve right at the moment, but have you considered a "Timer type valve, similar to the lawn sprinkler type? I don't think they are too expensive. Good luck..Hube
| There are none. |
