| Posted by Hube on July 01, 2003 at 10:08:33: | |
| In response to Re: point bounce on pressure switch | |
: The points are bouncing on my well pump pressure switch causing a staccato cycling of the pump motor which I'm sure is not good for it. What causes this & how do I get it to stop? : Thanks, : Steve Steve, The air pressure is not right. Drain the tank (shut off pump first) Pump air into tank ,so it's 2 psi lower than the cut-in pressure. This should eliminate the bouncing, and also give you more "drawdown" . A 36 gal tank at 30/50, should give approx. 8 gal. draw. Hube |
| There are none. |
