| Posted by hj on June 30, 2003 at 17:28:15: | |
| In response to Re: replacing a crappy low flush toilet with a sloan valve | |
In most cases you will not be able to do it, since the Sloan valve requires a much larger supply pipe than a house normally has, and the fix to make it work is also expensive. The valve cannot be retrofitted to a tank type toilet so you will need a new toilet also. : any idea on how to do this or where to get sloan toilet valves in seattle? also do i need a new toilet?
| There are none. |
