| Posted by Hube on June 30, 2003 at 10:56:08: | |
| In response to Re: CONDENSATION | |
: THERE IS A BUILD UP OF CONDENSATION ON THE COLD WATER PIPES (COPPER).How can I prevent/correct this? Oliver; Pipe insulation will help eliminate the condensation. Most hardwares sell it. Simply apply, taking your time to afford tight joints. The insulation comes in a foam, 3' or longer, and is slit along the length for easy application. Also there is apipe "wrap" for more difficult areas. Hube
| There are none. |
