Re: Leaking copper pipe
Posted by hj on June 29, 2003 at 23:51:02:
In response to Re: Leaking copper pipe
It could depend on which pipe it is and where the holes are occuring.
: Is it common for copper pipes to have a pin hole and leaks, just recently repair a pipe with a pin hole that was leaking water from the copper line in the basement , after that was fix another pin hole develope what is wrong with the pipe, does this happen commonly to old copper pipes.
Replies to this post
There are none.
