| Posted by hj on June 28, 2003 at 09:30:24: | |
| In response to Re: banging pipes & air when flushing | |
The air is either due to the construction of the toilets or insufficient water in the bowl when the tank is flushed. In the first case you cannot do anything about it. If it is a water level problem then you need to make an adjustment to allow more water into the bowl while the tank is filling. : : Whenever we flush the toilet, there is always air that bubbles up. Also, there's banging in our wall, but only in one section of the house, in our upstairs common bathroom, but the air is in all three toilets. The house in only three years old. Any ideas.
| There are none. |
