Re: Old toilet change out
Posted by Stevo on June 28, 2003 at 04:01:59:
In response to Re: Old toilet change out
I Have found in houses the have long horizonal runs of cast iron that the water from a low-flow (1.6gpf) flush toilet will "out run" the soild waste+paper, leaving it in the pipe untill the next flush. This can become a problem over time. If the house is plumbed with a smooth wall DWV system (i.e. PVC DVW/ ABS) it should not be a factor. : : I have a property that was built in the 50's. If I take the old toilet out which could be from 3-7 gallons? will the new 1.6 toilet flush ok , since the drain lines were designed for the bigger toilet that uses more water and what would keep the new 1.6 from flushing right
: : thanks
: : mike MIKE; Go ahead ,put in the 1.6 toilet, it will flush OK.The flush amount is controlled by the toilet mechanism,etc, not the supply or drain pipes.
Replies to this post
There are none.
