| Posted by Hube on June 27, 2003 at 18:14:14: | |
| In response to Re: Old toilet change out | |
: I have a property that was built in the 50's. If I take the old toilet out which could be from 3-7 gallons? will the new 1.6 toilet flush ok , since the drain lines were designed for the bigger toilet that uses more water and what would keep the new 1.6 from flushing right : thanks : mike MIKE; Go ahead ,put in the 1.6 toilet, it will flush OK.The flush amount is controlled by the toilet mechanism,etc, not the supply or drain pipes.
