Re: Rusted galvanized pipes...low pressure!!!!!!!!!!!!!
Posted by hj on June 27, 2003 at 14:03:59:
In response to Re: Rusted galvanized pipes...low pressure!!!!!!!!!!!!!
No. Sometimes you can run water through them backwards and flush out any debris that has created a logjam at a fitting. But if the pipe itself is badly corroded, then there is no solution, and if there were the process of removing the internal rust would usually cause holes in the pipe that the rust was sealing.
: HJ. Isn't there a way to pressureize the pipes and clean out some of the rust? I hear different stories.
Replies to this post
There are none.
