Re: leaking valve stem on frost proof faucet
Posted by Nick on June 27, 2003 at 09:12:45:
In response to Re: leaking valve stem on frost proof faucet
Technology has come a long way, but not necessarily with valves. The packing nut needs to be tightened around the stem, if that doesn't do it, the packing needs to be replaced. Good luck : My frost proof faucet on the front of my home leaks around the valve stem only when I open the valve to : run water. It does not leak when the faucet is shut off. The unit is mounted through the concrete block : foundation of the single level house. I would like to know how to repair the leak. Forty years ago, : I repacked leaking valve stems in ship board water systems (I was on a ship in the Coast Guard) with : wax or graphite impregnated string about the size of shoe laces. If that is still the technology, I can : handle that OK, but I suspect technology has changed. Any advice will be appreciated.
Replies to this post
There are none. |
