| Posted by hj on June 26, 2003 at 18:43:01: | |
| In response to Re: Converting a 10" rough-in to a 12" rough-in | |
1. You have to know the material the drain pipe is made of. 2. They require a certain amount of depth, usually achieved by cutting off the riser pipe. Not always an easy job for the DIY'er. 3. If you get the shallow ones they create a shelf under the toilet which can cause problems. 4. They only work if the correct one is used and it is installed properly. : Offset flanges work, that's why they make them.
| There are none. |
