Re: Basement bath rough-in.
Posted by hj on June 26, 2003 at 18:37:05:
In response to Re: Basement bath rough-in.
1.There are almost never any plumbing blueprints for houses.
2. If there are plumbing plans, unless they are marked "as built" they will be wrong.
3. There are no standards. The plumbing for a given residence will be installed the way the plumber felt like doing it that day.
4. If these are questions you cannot answer yourself, then maybe you should contact a plumber to check your system and install the drainage piping correctly.
: We are refinishing our basement. We plan to install a full bath.
: It will be located about 6-8 feet from one of two basement drain pipes that come together to the main drain. The other drain pipe is on the other end of the basement.
: My question is how do we "scope out" the path of the
: drain pipe running under the slab and what's the typical depth? So we can remove the slab that covers it.
: The pipe runs down the wall and has a cleanout and then it angles 45 degrees (?) into the floor. Typically how far from the wall and footer will
: it run? The main drain is not a straight line from this pipe as the foundation extends three feet further out (toward the street) where the main cleanout is located. (We do not have any plumbing blueprints of the house - built 1996).
: I have read several plumbing books and watched a few videos but none have addressed typical dimensions except for distance from sewer to drain and into home to main cleanout. From there, I do not have an "exact" clue.
: Thanks.
Replies to this post
There are none.
