| Posted by hj on June 26, 2003 at 09:27:35: | |
| In response to Re: Rusted galvanized pipes...low pressure!!!!!!!!!!!!! | |
Other than replacing them with plastic pipes there is no sure way to fix them. There is a company that says they can "sand blast" the pipes and then line them with an expoxy coating, but since they can neither inspect the pipes after cleaning them to be sure that all the buildup is gone, nor see if the coating adhered to the entire pipe, you could not be sure that the process was worth the expense. : What can a plumber do to increase my water pressure in my rusty galvanized pipes....short of replacing with copper?????
