Utility Tub in garage
Posted by Trey in Austin on June 24, 2003 at 17:15:57:
I recently moved into my first home and I would really like a utility tub in the garage for cleaning up messy projects instead of taking the stuff into the kitchen. There are no other water connections in the garage besides the washer ones.
Are these sufficient to do what I want to do? Can I just split both the hot and cold water connections to go to the washer and to the tub then have them drain into the same drain? I am a real novice at this so please give as much detail as you can.
Would there be any problem with the utility tub backing up or would it be able to drain?
Thanks in advance for the help.
Trey
Replies to this post
