| Posted by LonnythePlumber on June 21, 2003 at 23:31:31: | |
| In response to Re: Wall Hung Toilet Geberhit Pre Wall Carrier | |
: We have, or had a Kohkler wall hung unit. The Waste hole is at the top, 6 inches from the floor. : We are trying to install a Geberhit, pre wall carrier. The lowest setting, allows the waste hole to be 8 inches from the floor. Not including the 2x4 it will be installed on. : Supposedly, if the holes were lined up I woul;d not have a problem, but they are not. Since waste will flow down hill, it there an attachment I can get from the pre wall carrier to the present waste hole. : Failing that I have been told the plumber will have to drill a hole in the floor for the waste line, but their is floor joist in the way. I have also been told to open up the wall, cut out the old carrier, intall a new one that is higher and inline with where I want to have the carrier connect, 17-19 inches off the floor. : Help The face of the carrier should be adjustable. This allows us to put four carriers in a row all 3/4" lower than the previous one, but to have all the toilets at the same height. I would cut open the wall, adjust the carrier face and repair the wall. LonnythePlumber |
| There are none. |
