| Posted by Deb on June 21, 2003 at 10:41:26: | |
| In response to Re: Cycling well pump | |
: I have a well pump that is used for irrigation only, and it has been cycling from day-one. I am not sure which is worse for the motor and/or pump: cycling (constantly going on/off) or running continuously for < 1 hour at a time. : I think that cycling is worse as the pump should be able to take an hour of work without a problem. Any thoughts? : Thanks!
| There are none. |
