| Posted by Scott on June 19, 2003 at 08:54:39: | |
| In response to Re: bath tup stopper | |
: I have a stopper in my tub that screws up or down, open or closed. I can't remove it to insert a snake/hair. I have tried prying it out to no avail. I don't care if it breaks, so how do I remove it? : Thanks alot for shareing your knowledge. If it is like my claw foot tub stopper it doesn't "screw" up or down - you lift it and give it a 1/4 turn to lock it "up" - and 1/4 turn to release it and let it go down. If that is the case, you need a thin flat head screw driver to access the screw on the base on the stem of the stopper. A screwdriver with a small handle is best since you will need to run parallel to the bottom of the tub and into the drain opening. If you stick your head in there - you should be able to see it.
| There are none. |
