Re: gas water heater
Posted by Hube on June 18, 2003 at 09:37:39:
In response to Re: gas water heater
: I am purchasing a manufactured home that has a gas water heater that has no oxygen venting system. Yes, it has the normal vent through the roof but it has no source of getting oxygen when the door panel is in place as it normally should be. How do you suggest venting the unit to outside air ? I was told to go through the floor...if so, how do you stop insects from coming in the same way ?
: Thanks ! A heat recovery system ;HRV will do it
Replies to this post
There are none.
