Re: No hot water
Posted by Hube on June 15, 2003 at 08:49:02:
In response to Re: No hot water
: Hi, I think there's probably a very simple solution, but as I have absolutely no clue and no plumbing skills/knowledge I need help. Our master bath has two sinks. One is working perfectly. The other was working fine until just a few days ago. The water does not run when I turn the knob for the hot water. It is a Moen product. I tried looking underneath the sink to see if maybe I had accidently shut off the water somehow, but there doesn't even seem to be knobs to control the water flow. Any ideas? Am I missing something? Poster;I am assuming the coldwater tap is ok. Look for a kinked or pinched flex line under basin. Also, the pipe could have some debris, or crud build-up , so remove the faucet screen and run the water and see if that will clear it. good luck ..Hube
Replies to this post
There are none.
