| Posted by T. White on June 14, 2003 at 18:30:21: | |
| In response to Re: water softener not functioning | |
: A few weeks ago, my softener brine tank filled all the way up and remained there : for several days, as the water in the tank continuously ran outof the overflow. I continued to get soft water : for a few days until (presumably) I ran out of salt. Then I turned it to "bypass". I have spent the last few : nights trying to fix it. I disassembled the inlet and the main and injector valves, looking for sticking or : blockage. : Having found none, I checked the timer function. The timer appears to be working perfectly and the : control seems to cycle the valves correctly. I'm wondering if the "regen" cycle is working, since I don't : hear the water rush into the softener cylinder : when its in the "regen" cycle. I do notice the backflush and rinse cycles seem to work, judging by the : water discharged from the hose. I took the brine tank out and cleaned it before putting it : back in service. I put a few gallons in by hand and the level seems to maintain lower than it had previously : when it worked correctly, but it isn't dry. : I'm stumped. The softener appears to be functioning, I think salt is being consumed, : but no soft water. I have the feeling I'm overlooking something simple, and I don't want to : buy a new one if that's true, even if the local home supply people tell me that's all that can be done. : Moreover, I don't even know if putting in a new one will fix the problem at all. : What else should I look for in order to solve this? I can't even : find the manufacturer (AquaMaster) on the internet, and local contractors have not heard of it. I have the same problem. Just happened, and now my water pressure is low. How did you solve your problem? r/ T. White |
| There are none. |
