sealing under walls
Posted by Lolen on June 12, 2003 at 12:03:34:
I don't know if anyone here can answer this, but.... I'm remodeling a barn into a house. The foundation is very solid and thick, but there are no cement "curbs". In other words, the walls sit flat on the cement and the inside is the same level as the outside, so if I spray water hard against the outside, the water runs under the walls into the inside. How would I seal under the walls so that water can't enter after I remodel? Normally, the foundation drops where the outside wall is, so water would be below the foundation. Any tips are appreciated!
Replies to this post
