| Posted by LonnythePlumber on June 11, 2003 at 22:55:37: | |
| In response to Re: HJ, what is coming out of shower | |
: Then they need a plumber who knows how to unplug a drain, and in that case, "backflow" is the problem not the solution. : : HJ, : : Could it be that water coming out of shower refers to the drain, not the faucets. A little Pennsylvania Dutch dialog? : : PW : : : : : I recently had a plumber replace the stems in the hot and cold water handles - and also snake my tub drain. Since then the water has stopped coming out of the shower. Since I am not a bath person - this causes me a real problem. The plumber recommended back flow - I think that was what it was called. We tried this and it was no help. Any suggestions would be greatly appreciated. Debris may have washed into the shower head. Remove it and check your flow. If not it may be debris in the diverter in the cross of the faucet body. LonnythePlumber |
| There are none. |
