Re: Leaking brass to PVC conection under Tub
Posted by hj on June 10, 2003 at 09:47:15:
In response to Re: Leaking brass to PVC conection under Tub
Which plastic to brass connection? The only one you should have would be the one where the drain goes into the verical pipe and that one should only leak if the drain is plugged up.
: I am replacing my tub and can't stop the leaks aroung the joints that are mating up. I replaced everything as original with putty around the drain. The only thing I can't get to stop leaking is the plastic to brass connection. What if anything can i use as an adhessive to stop that. I know it can't be normal putty do to the placstic nut and seal. Thanks for any help.
: Don
Replies to this post
There are none.
