That's what I was afraid of (i.e. no combination of parts that will make this easier than using inline adapter connectors everywhere).Thanks Deb! (Pipewench, hee hee) : : : : Yes, thanks Deb. But I want to connect PEX to a PB elbow or T. Otherwise I have to do like you say and add an inline connector everywhere. I would like to avoid adding an inline and connect PEX directly to a PB fitting. : : Thanks! : : That's not going to happen....:-( : The interior diameters are quite a bit different. : Deb : The Pipewench : : : : : My house was built in 1988 and has PB (gray) pipe with mostly plastic fittings. As I do repairs I would like to replace sections with PEX. I have the crimpers and they work on either pipe. I understand the crimp rings have different ID's so are not interchangeable, and that the PB fittings have 4 or more ribs while the PEX fittings have 2 ribs. My questions are: : : : 1) Can I attach PEX pipe to a PB fitting? If so, how? : : : 2) Can I attach PB pipe to a PEX fitting? If so, how? : : : I ask this because I would like to replace sections at the fittings (U's and T's) and I only know of inline connectors for joining PEX to PB. I don't want to repipe the whole house and I am not having any leak problems (just normal faucet type stuff that needs replacing). : : : Thanks Terry, : : : Chris
