| Posted by Deb on June 08, 2003 at 21:06:53: | |
| In response to Re: 3 piece tub/whirlpool/shower unit | |
: Im considering installing a three piece tub/shower unit in my bath room as a part of an entire remodel. : the problem im having is that i cannot find any info on the intial frame work. : i know ill need a mortar base and cement board liner of sorts : but does any body know the dimensions to fit a 60" x 32"x 87" kit? : i surfed the manufactures website but found nothing. the kit is made by GALBOCCA. : kind of a bummer cause i cant frame my new door opening until i find out where the completed deal is going to set. : any info to keep job rolling well be apreciated Some tubs do not need a mortar base (never heard of using cement board). A mortar base, if you need it, goes down when you install the tub, so don't worry about it now. And I don't quite understand your framing problem. You have the dimensions you need. |
