| Posted by LonnythePlumber on June 08, 2003 at 19:26:03: | |
| In response to Re: Cast iron sewer pipe | |
: "You will probably need to have the cast iron line cleaned for it to take the faster dump from a washing machine. This is usually a $150.00 to $250.00 not including the drain cleaning." : If I may........What do you mean by "cleaning"? Cleaned with a machine. If you observe a pattern of when the line needs to be cleaned you can schedule regular cleaning before a stoppage occurs. Not all cast iron needs to be cleared. LonnythePlumber |
