Re: new tile need adjustable wall toilet flange
Posted by LonnythePlumber on June 08, 2003 at 19:22:46:
In response to Re: new tile need adjustable wall toilet flange
: : We are remodeling a motel, putting in new tile which raises the floor too much for the existing flange to work. Is there such a thing as an adjustabe flange that will allow the old toilet to be reinstalled about 1/2" higher?
: The tile needs to go under the flange. The flange should sit on top of the finish floor or you may be limiting the life of the floor. The flange area is a great place for water to get underneath the tile. Whether your flange if plastic, cast iron or brass you should replace them. LonnythePlumber
I failed to notice your wall and mispresumed floor. Most toilet carriers have a four inch screw in pipe the toilet sits against. You should be able to get a new plastic stub out and cut it to length after you have installed it. LonnythePlumber
Replies to this post
There are none.
