| Posted by hj on June 08, 2003 at 19:04:47: | |
| In response to Re: follow=up to phantom flush problem posted on 5/30 | |
It is probably the correct part, but installed wrong. : We replaced the flush valve unit in our CW toilet. To do so we had to shorten the overflow pipe and we removed the styrofoam float attached to the chain. Now there is a glitch: the flapper does not seal in its flush valve seat and there is a leak between the tank and the bowl,HELP! Did we buy a wrong replacement part?
