| Posted by hj on June 08, 2003 at 10:05:37: | |
| In response to Re: Toilet Tank hairline crack | |
And plumbing being the way it is, that tank could crack 10 minutes after you leave on a two week vacation. When that happens, I have seen it or a similar situation many times, the water will run until you return home or the neighbors see the water running out from under your door. : : What do you have to lose? Gary Swart : Well..........You could loose quite a bit.
