| Posted by hj on June 07, 2003 at 16:18:54: | |
| In response to Re: Gerber ultra flush toilet won't flush | |
That is what happens when the pressure flush toilets lose their air bubble. You need the manual to see how to replenish it. Usually be removing the flushing valve and letting all the water drain out of the tank so it fills with air. : My 7-year old Gerber Ultra Flush (which my family LOVES) has stopped flushing. It sounds as though there is no longer any air inside the flushometer. when you try to flush, it makes a weird sound, then a few bubbles appear in the bowl, then nothing happens. I called my plumber and he has no idea how to even install this type of toilet, let alone repair it. Any suggestions on what might be wrong? Thanks
| There are none. |
