| Posted by Mike on June 06, 2003 at 13:53:11: | |
| In response to Re: Mounting toilet flange to basement rough-in | |
: When I had my house built, the plumbing contractor roughed-in waste lines for a half bath. I'm ready to finish up the bath now and am confused about how to mount the toilet flange given what I see coming out of the concrete floor. : I am not installing a subfloor; vinyl flooring directly onto concrete. : I see a large PVC pipe rise approx. 1" out of the concrete. I measure 5" OD on this pipe. Inserted (and presumably solvent welded as I see purple cleaner) : Given that I want the toilet to basically sit on the concrete (height of vinyl flooring can't be more than 1/8"), I'm not sure how to proceed. I think I have to cut the large pipe almost flush (allow for vinyl floor thickness) with the concrete and then find a toilet flange that slips inside this large pipe. I looked for a toilet flange but see nothing that had a 4.5 OD". : I'm beginning to suspect that the contractor assumed I would have sub-floor. This is not possible d/t transition into bathroom and ceiling height limits. I really don't want to have to build up a small toilet pedestal to get around this problem. : Any suggestions would be appreciated.
| There are none. |
