| Posted by hj on June 05, 2003 at 16:57:15: | |
| In response to Re: baseboard heat options | |
You either install dummy base to cover the pipe, or you have to open the floor, or ceiling below, to install the pipes to the working locations. : i'm looking for options for running the pipe for baseboard hot water heating in a new second floor installation. the pipes come up to the second floor in the bathroom. i need to run the pipes through both sides of the bathroom to heat the two new bedrooms. my plumber says that i have to have "false baseboards" along the bedroom walls to hide the pipes leading to and from the actual vented baseboard unit. this means that at least half of my baseboards will be covered. i really don't like this idea. what are other less obtrusive ways of running the pipe (without ripping out first floor walls)? i live in new england where pipes have been known to freeze in the winter. thanks.
| There are none. |
