Re: Hooking up two dishwashers
Posted by hj on June 05, 2003 at 16:53:34:
In response to Re: Hooking up two dishwashers
They cannot share a drain connection. You can connect onr to the garbage disposer and the other to a branch tailpiece tee under the other sink's drain.
: What is the correct way to connect two dishwashers? Can I share the same air gap and a single connection to the dispoal. Is there a way to put air gap under the sink. By this I mean is possible to connect the line to island style vent. Could I just have the plumber put in a seperate drain connection just for the dish washers? Thanks Andy
Replies to this post
There are none.
