Re: smelly water from hot faucet
Posted by PJ on June 05, 2003 at 11:46:17:
In response to Re: smelly water from hot faucet
: : : Why does the water from our hot tap smell kind of like sewage? The cold water doesn't. Is there a leak or seapage somewhere? Are you sure it's a sewage smell? Most likely it's hydrogen sulfate, usually normally found in HW tanks. Some times draining tank and ridding it of any sediment may help. Are you on city or well system? [I'm on city water.] If on well, shocking (bleach) may help. Hube
: Your anode tube needs to be replaced.LonnythePlumber [What/where is the anode tube?]
Replies to this post
There are none.
